I am Using TPS54160 Ic for Vout= 5V , Input voltage is = 24V and outptu current = 1A
I have simulated the design in WEBENCH and working good. but i want to calculate manually the values for Frequency compensation components.
Till calculating the Crossover frequency Fc, results were oK, but i stuck at calculating the value of gain of Modulator(Gmod) at Crossover frequency.
As per the datasheet TPS54160, the value of Error amplifier transconductance (gm) is 97μMhos, but using this results are not oK.
Also in formula of Gmod it is mentioned as gm(ps), what's the ps means ??? Or do i have to convert the given gm value in different form ??
