Hello team,
I bumped into an LED driver from Integrated Device Tech. (IDT) called ZLED7001ZI1R:
Due to obsolescence my customer started using the Microchip HV9910B which is not a pin to pin.
I' m looking for a replacement LED driver that I can recommend in this case; the needed Vin is 10Vdc – 130Vdc. Pin to pin with the ZLED7001 would be great, or at least similar.
I found that the LM3402HV is similar but doesn't have the right Vin. Do you have any suggestion?
Please let me know.
Thank you and best regards,
Adrian
