Other Parts Discussed in Thread: CSD13381F4
Hello
i would like to make bms using bq76940 for my 48v 100AH 13s battery pack . but the maximum current is given as 20A.can you give me clarity on this
thanking you
Thrishool G
Hello
thanking you
Thrishool G
hi
Tq for the response i have another query. i would like use an external balancing .So what should be the rating MOSFET rating i need to choose to place across each mosfet. I have seen some document which recommended to use CSD13381F4 but the maximum current rating is 2A. MY doubt is my charging current is 30A ,so during balancing if any of my cell exceeds the voltage my mosfet starts to discharge the that excess but during this time my other cell will charging right,so during this current my does that my charging current of 30A will be passing through this balancing mosfet or not.in case it diverts then mosfet rating should be high.
thanking you
Thrishool G
