TPS65400: TPS65400 is used in 3 outputs case
Part Number: TPS65400
Hello team,
I am considering to use TPS65400 3 outputs  I will not use SW4. I would like to reduce the external parts for SW4 outputs.
Can we remove the parts that I showed in red as the attached schematics? If not, would you please treat some pins after EN= disable?
Your advise would be so appreciated.
Akihisa Tamazaki
