Other Parts Discussed in Thread: TLC59116
Dear all.
is there a way to increase the power on reset time?
Our customer is looking for 1us capable automotive device.
Thanks.
Dear all.
Thanks.
What is the target application? Normally power on reset time is tens of us time for most devices to get internal logic ready. If there is any special requirement, we can think about some work around solution on both hardware and software.
Thank you for your prompt reply.
Thanks.
Hi Mike,
The POR time is a fixed parameter for such device. If users worry about the Vcc voltage, I would recommend to optimize the power supply circuit.
Thank you for your reply.
ESD must be satisfied by contact 10kV.
The cause of Flickr is currently occurring from 3kV and the reason is file attachment.
You have already applied everything you have told me, especially the higher the cap. value of Vcc, the greater the trnsient.
Can you check the layout for any modifications?
Or, I'd like to ask you if you have anything else to check.
Thanks.
We are all clear that I2C is not a good choice for long distance communication, CAN/LIN is good at off board communication.
The only way we can suggest is add the cap to do the filter cicuit.
