TPS53353: How to evaluate the OVP function of TPS53353?
Part Number: TPS53353
Hi expert,
My customer wants to know how to evaluate the OVP function of TPS53353. In the datasheet, it's said that if the feedback voltage becomes higher than 120% of the target voltage. The customer wants to test the OVP situation, but doesn't know the correct method. If changing the feedback network, the output voltage will also change, and OVP threshold changes as well. The question is how to check if the circuit will trigger protection when the output voltage reaches 120% target value.
The customer is urgent to know this question. Could you give me a reply today? Thanks a lot!
