Part Number: TPS65131
hi expert,
Can you pls confirm if TPS65131 able to support below output spec from 5V input?
+15V: 500mA
-15V: 300mA
Thank you.
hi expert,
+15V: 500mA
-15V: 300mA
Thank you.
Hello Ken,
TPS65131 boost switch current limit is minimum 1.7A and with high conversion ratio at Vin=5V, Vout=15, switch current will be higher than 1.7A at 500mA load. So TPS65131 can not support this application condition.
Kind Regards,
Liaqta
