TPS5130: PG not coming up
Part Number: TPS5130
Hi Team,
my customers has the problem that sometimes the PG pin doesn't come up. They can get the PG pin up when they reduce the output load or when they remove the capacitors on the PG_delay pin. Currently they have 200nF on the PG_delay pin. Is the value too high for PG_delay? Is there any other reason the PG pin could not come up? All softstarts are active and all voltages are up and in the right range.
Best regards
Simon
