TL7700: Vcc and Vs
Part Number: TL7700
We got a question from the customer about TL7700.
Could you help us?
[Question]
Are there any voltage level requirements between Vcc and Vs? They are concerned whether Vs voltage allows to exceed Vcc voltage, or not.
tateo
  • Tateo,
    VCC and Vs have the same recommend operating range and the same ABS MAX spec. Be sure to never go above ABS MAX. If you need Vs to be higher than VCC, please use an external resistor divider so Vs at the pin never exceeds VCC.
    Please let me know if you have additional questions. Thank you!
    -Michael
