TPS51206: TPS51206 supported temperature range
Guru 11170 points
Part Number: TPS51206
Hello E2E,
TPS51206 supported temperature range was chang from "-40 deg to 85 deg" to "-40 deg to 105 deg".Characteristic graph of the datasheet remains maximum 85 degrees.
Is there characteristic data of maximum 105 degrees?
Does TI has plan to revise the datasheet?
ACGUY
