TPS25942A: PGOOD Minimum
Part Number: TPS25942A
Hello E2E,
I would assume that there would be no minimum voltage requirement for the open-drain output of the PGOOD signal (assuming you don't violate the PMOS transistor saturation equations), but I wanted to double check.  With 12Vin, is pulling up to 2.85V ok?
Thanks!
Russell
