Other Parts Discussed in Thread: TPS65218D0
Hello there!
I am performing a failure analisys on TPS65217 and was looking at a external short circuit fault that could occur on the externally fitted capacitors fitted to pins INT_LDO and BYPASS. These pins are internally connected to the TPS65217 internal Bias block which powers various internal references which are not detailed in the datasheet. The datasheet only says that these pins (INT_LDO and BYPASS) must not be loaded however it does not say(at least I haven't seen it) what is the the effect it that occurs.
My question is- would a short to GND in any of these pins cause a "lock out" or any other misbehaviour on the part?
Thanks in advance.
