LM5575: Generate closed loop Bode plot
Part Number: LM5575
I'm working on measuring the closed loop Bode plots for the following regulator. Using one of our production units, I have inserted a 1k resistor to create a high Z / Low Z impedance nodes.  Then using the Frequency Response Analyzer, I inject a signal via CH1 (1k and R50 node), and measure the response on CH2 (1k and C226 node).   See the picture below.
I'm getting unusual phase measurements.  Can anyone recommend what I'm doing wrong?  Do I need to move the insertion point before the OUT (Pin 11) connection?
How does TI measure the closed loop performance that it shows in the Webench simulations?
Any help would be appreciated.
