BQ76940EVM: Keyin to control discharge preventing charge
Part Number: BQ76940EVM
I am using a switch across keyin to turn the discharge fets on and off. When I use a power supply to charge my battery pack the discharge fets are turned on to allow it to charge and then are turned off when the charge completes. However, when I use a "smart" charger the charger does not see any voltage at the terminals and does not initiate a charge. Is there any way to allow a charger that senses voltage before initializing to work while keyin has discharge set off?
-Kyle
