Other Parts Discussed in Thread: BQSTUDIO, EV2400
Hello sir,
Got a new problem ...i did all require step for battery through fuel gauge in bqstudio..and generate golden files as well..
and for production of fuel gauge .... i made code to write data of my df.fs file into fuel gauge through microcontroller(STM32L053).. but before that i set default value in data memory..so i can check after programming that data has changed or not...
after set default value ...i program my flash memory data into fuel gauge through code...
and after that i open bqstdio ... but fuel gauge does not detect in fuel gauge... i wake-up fuel gauge but it does not detect...even i connect my charger but no change...why its happen after program ??
i think fuel gauge ic damaged...if yes then why ?
