Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
LM22670: LM22670MRE-ADJNOPB 15V Vout Divider Resistor Value Problem
Part Number: LM22670
Hi TI EE:
               My buck power using LM22670MRE-ADJNOPB ,Vin:24V,Vout:15V .
               I have trouble to make sure the divider resistor value.Please help to make sure the bellow figure which one is better.
             Thank you!
Best Regards
Cheney_Sun
    From my calculations, the first option would give you an output voltage of 14.996V, and the second option would give you an output voltage of 15.017V. Both options will give you approximately a 15V output.
    Please let me know if you have any additional questions regarding the voltage divider.
    Katelyn
