TPS386596: Vsense to RST signal delay specific
Part Number: TPS386596
Hi Team,
I'm penetrating TPS386596 in my customer side, customer want to know the time delay from sense VIT(Voltage drop and trigger VIT) to RST pin pulled low, but it seems these is no data for this delay in datasheet, knowing that is should be very small, but customer want to know this specific because they need very quick response, would you pls kindly help check on this? I find such kind of specific in Maxim's part, the delay less than 500us. We want to know what's the time delay for  TPS386596.
Sulyn
  • Sulyn,
    Please use Tw (SENSE) to determine the falling propagation delay. Keep in mind that 4us typical is provided with the MAX value not given as this value will be affected by operating conditions and application. Reducing parasitic capacitance on the /RESET output will reduce the transition time.
    If you need bench data or have additional questions, please let me know. Thanks!
    -Michael
