CCS/BQ25703A: BATDRV issue
Part Number: BQ25703A
Other Parts Discussed in Thread: CSD25402Q3A
Hi
I'm using BQ25703A on my board.
My question is could I control BATDRV?
Actually I want control CSD25402Q3A.
please give me details. Thanks
Bye
    /BATDRV should be controlled by our chip. BQ25703A will control /BATDRV signal condition based on operation mode.
    But if you want to change status of /BATDRV, maybe you can use below register.
    1. ChargeOption0: EN_LEARN bit. If you enable learn then BQ25703A will force turn on /BATDRV to discharge battery
    2. Chargeoption0: CHRG_INHIBIT bit. If you disable charger then BQ25703A will turn off /BATDRV to stop charge battery
    Hope this explanation can clarify your question.
  • Thank you for the answer.
    After test, I 'm going to reply about that.
