TPS63051: Reduce output ripple
Part Number: TPS63051
Hi, I'm checking TPS63051 evaluation board and I need to reduce the output ripple voltage.
My device drains about 30 mA when is active and about 2 mA when it's sleeped. With this currents I see that the TPS63051 output voltage ripple is about 15 mVp, what it's too much for my needs.
What do you recommend in order to reduce the ripple? Something under 5 mVp would be ok. It's for a battery powered wearable device, so the footprint area is relevant.
Thank you
