Hi team,
Can the customer use following crystal with relaxed spec to some extent for PMIC? PMIC doesn't require 16MHz crystal for the operation, so I assume relaxed spec crystal will be used for PMIC, if accurate external clock output is NOT required.
<16MHz crystal spec>
±50 ppm at -40C to 105C
The customer commented they just use power supplies of PMIC and I2C, don't use ADC, RTC.
Thank you for your support.
Takeshi Sasaki
