Part Number: TLC5916
Other Parts Discussed in Thread: TLC59282
I have problem in setting the current configuration code correctly. It seems that even if I change the current configuration value to diffrent values it always seems the same.
I followed the sequences provided by the data sheet. 1. first change to special mode 2. then sending configuration value, followed by toggeling the latch enable. Can you please clarify the sequence given in the datasheet?
