I noticed that the datasheet lists the x and y dimensions and their mechanical tolerances, however the thickness dimension only shows a 1 mm MAX dimension. What is the nominal and minimum height of this component?
Hi Mr. Ma,
The max thickness dimension of 0.625 mm just gives the up limit only; the device has no nominal and minimum height measured.
