Other Parts Discussed in Thread: LM2596
While doing the short circuit test of the circuit built with LM22676, it is observed that the LM22676 IC gets damaged(short). Circuit used for testing is same as the typical application circuit mentioned in the datasheet. Enable pin is kept floating. Similar test is also done with IC LM2596, the IC doesnt get damage.
