BQ40Z50-R1: bq40z50-r1
Part Number: BQ40Z50-R1
Other Parts Discussed in Thread: BQ40Z80
Hi TI suport group,
    I found there are 4 temp senses and one fuse pin on bq40z50-r1 device. Could I program the device to heat the battery pack when low-temperature environment?  For example, using one temp sense to sense the pack temperature, when temperature fall below -10 degree, device's fuse pin will output a high level to control the FET on to heat the pack, and could put the FET OFF when temp of pack up to 10 degree. Thanks.
