TPS546C23: output current reading is different from real current draw
Expert 6470 points
Part Number: TPS546C23
Team,
we observe a problem with TPS546C23 - the value of the output current that we read from TPS546C23RVFT is way off from the current that we draw with load.
The other problem is that value from the register of output current is changing with input voltage while keeping output voltage and output current the same. Differences that we get are not changing linearly so we can't solve this problem just with offset.
We have prepared design files to share offline.
Thank you for your help
TI Customer
