BQ35100: Error from TI Gauging Parameter Calcukator
Part Number: BQ35100
TI Gauging Parameter Calculator reports the following errors:
Accuracy Error: Deviation is so high that it is most likely due to anomaly in the data. Please check that data files have recomended format, units and test schedule
I have reviewed the log file and increased the accuracy, but I still get this error.
* Warning: Discharge rate is too high. High rate reduces ID detection accuracy
I use C/20 as discharge current. This is the lowest current recommended in your instructions SLVA725A, "Simple Guide to Chemical ID Selection Tool (GPC)".
Please advice.
Claes-Henry
