Hello TI-team,
I am planning on using the UCC28780 for an upcoming design. What exactly will set the upper limit on the flyback switching frequency? In the design examples for this IC, GaN switches are used, and are switched at around 400-500 kHz. I will use Si MOSFETs instead, so perhaps I should try to keep the maximum switching frequency a bit lower. What do you think?
BR
