What is the best option of a driver to use in a Synchronous Rectification for boost converter using full SIC Semiconductors?
Daniel
Daniel
Hi Daniel,
I am an applications engineer on the drivers team and I can help you with your question.
Take a look at the SiC homepage: www.ti.com/SiC
You can find gate drivers that can drive SiC MOSFETs, reference designs and technical collateral that can help you with your design.
If this post answered your question, please press the green resolved button.
Mateo
Hi Daniel,
If you need a drive for both SiC MOSFETs in the boost converter, you may consider using dual channel driver UCC21530 (www.ti.com/.../UCC21530).
If you only need to drive Synchronous Rectification MOSFET, you may consider using a part in UCC53x0 family (www.ti.com/.../sllser8f.pdf) depends on required driver strength.
Gangyao
