Hi team,
In datasheet of LMR14050-Q1, it seems that there is no spec of minimum soft start time.
-. Is it okay although SS pin is floating?
-. When not using Css, what is the min. SS time?
Sam Lee
Hi team,
Sam Lee
SS time is almost zero if SS pin is floated, but the output capacitor require charging up time. SS time must be larger than output cap charging up time otherwise it may cause startup issue. the minimum SS pin currrent is about 2.1uA.
