BQ25890: Power setting time
Part Number: BQ25890
I found the BQ25890 in using,  from the power supply input +5V  to SYS output 3.7v, the setting time is 3s.
I would like to ask whether this time is normal, whether there is a way to shorten?
  • Please refer to Figure 48 and Figure 49 on the BQ25890 datasheet, the 3 seconds from applying Vbus to ~3.7V Vsys is longer than expected. You can check REGN voltage and /PG to make sure the supply has no delay.
