Other Parts Discussed in Thread: LP3996
My application needs to use 3.3V, 3.3V and 1.8V power supply. So, I am looking for a LDO regulator that can output 3.3V, 3.3V, and 1.8V to minimize circuit size. Required power on sequence is: 1.8V-->3.3V_1-->3.3V_2. Somehow I can't find one. So, I try to use
LP3996SD-1833/NOPB |
the dual one to reduce size a little. But its data sheet says there is timing control between out1 and out2. May I add an delay RC filter between Enable 1 and Enable 2 for controlling output timing between out 1 and out 2?
If you have another LDO with all 3 required output, it would be better.
