Other Parts Discussed in Thread: TLC59108
Hello all!
Thanks for watching!
For my project a LED PWM driver is probably the best option and my question is regarding which one to choose.
Chosen are 4 CREE RGB SMD Led's to be driven independently. The current per channel should be 150 to 200mA per channel.
This narrows down the options I know.
Q1 is it necessary for the driver to be a RGB version (subfamily) or any other with PWM will do ? (the LP8863 for instance)
Q2 would you choose a model with internal or external FET's ?
Q3 one driver (3-ch.) per LED or a 12 to 24 channel model ?
Q4 PWM or constant current?
Q5 for a better (what is better) quality of dimming a minimum of 12 bit should be maintained, do you agree ?
Q6 I am really searching for a guide to help me design the above, could you point me one ?
Hope this gives some idea of what the project is all about and if you have the time a reply please do!
Even more, when you do live in Holland and have the knowledge about all of the above maybe we can get together?
Thanks in advance!
Henk
