Other Parts Discussed in Thread: BQ24072, BQ25895, BQ25606, BQ25601
Hello.
I need to select li ion (1-cell) charger with temperature control that can provide system power when temperature is out of li ion charging range.
Hi Anatoly,
I can help! What is the battery's capacity (or your desired max charge current) and the input power voltage range? Do you want to charge in the standard temperature (0-45C) range or JEITA (0-60C) range, which modifies the charge profile below 10C and above 45C?
