BQ40Z50EVM-561: BQ40Z50-R1
Part Number: BQ40Z50EVM-561
What is the exact difference between Charge Suspend and Charge inhibit in the Fuel gauge .
Naveesh
  • CHG SUSPEND suspends chg when in chg mode at high and low temps. After chg relax time it changes to CHG INHIBIT. If you re in relax, with 0 current, then if the temp is high or low, charging is prevented if CHG INHIBIT is set. However, if you're already charging, CHG INHIBIT won't set until the current stops.
