BQ27520-G4: The manual command IT_DISABLE doesn't works
Part Number: BQ27520-G4
I have executed succesfully the learning cycle, and I am ready for production. How can I to disable the guage? I have tried to send the command 0x0023 manually with bqstudio, but it doesn't works.
What are the numbers, exactly, to insert into "manual control panel" of BqStudio?
  • Hi Filippo,
    This gauge has an IT enable paramter in the data flash. To disable IT for your golden file, ensure that parameter is set to 0. When you enable IT by sending command 0x21 after programming the golden file, the it enable parameter in data flash will get set to 01
    thanks
    Onyx
