Part Number: BQ76PL455EVM
I am working on bq76pl455 EVM. From the user's guide SLUUBA7A of the GUI, it is given we can stack up to 6 EVMs. In my application, I have 20 modules each with 14 cells. My question is should I need 20 EVMs to work with the entire pack? Is there any other solution for that? In the datasheet, 8.3.2it is mentioned that the devices will respond in sequence, starting at the highest address with the sampled data, then How my main controller will take the highest address because I will make 5 EVMs as one stack (4*5=20 EVMs)and I need to connect that 4 stacks to one main microcontroller. How can this be possible?
Thank you in advance
