Hi team,
I got the followings questions from a customer. Can you answer its?
-. Is there any timing spec for min. off time when toggling EN pin (High -> Low -> High)?
-. When EN pin is enabled, is there any timing spec required for ERR pin to stablize?
: For example, "The 16-ms (typical) reverse-current blanking can help filter this ringing.", is it associated with above question?
Sam Lee
