Other Parts Discussed in Thread: BQ78350
We are using the bq78350 fuel gauge in a customers battery which is sometimes stored for an extended period of time (few months). To maximize shelf life we wanted to understand if the low power SHUTDOWN Mode feature of the bq78350 is a viable option to use while the battery is sitting at the customers storage facility.
As I understand it, Shutdown mode can be entered in three possible ways: low voltage, time delay, or ManufacturerAccess command. The technical reference states that upon exit from shutdown mode, the gauge will undergo a full reset. Is that true under all three entry conditions? If so, will the reset cancel the learn cycle we perform just prior to shipping to customer? Does the learn cycle have to be repeated in order for the fuel gauge to correctly track capacity, or would it be enough to simply perform a full charge?
Thank you,
Maciek Lewandowski
