Other Parts Discussed in Thread: BQ76PL455A
Hi team,
We have just received the customer's feedback about incorrect behavior that they cannot read the correct value of AUX temperature at first read of the values of voltage and AUX temp after the initialization of the device with bq76PL455A-Q1 Example Code 1.0\bq76PL455A-Q1 Example Code and sys_main.c. For this issue, could you provide us with your answer/comment for the below?
(1) Currently the customer can read the correct value for AUX temperature by using dummy read at first time. Do you think that is suitable workaround for this issue?
(2) Please let us know the necessary processes after "select cell channels 1-8" and "AUX channels" in the initialization of the device?
(3) Does this device need some wait time to read voltage and AUX temp values after the initialization of the device?
(4) Do you have any other workarounds to remove this issue?
Jun
