Other Parts Discussed in Thread: BQ25504, BQ25505
I'm working on a project, where I just want to use the BQ25570 IC to charge a Li-Ion battery. I don't want to use the Vout or the buck converter option of the IC. I won't also connect an inductor at the LBuck pin, so I'll be connecting the Vout_en pin LOW.
My question here, If I don't want to use the Vout pin, as well as the Lbuck pin, Will the IC work properly if they were left floating, or should I connect them to something (eg. to GND).
Thanks.
