Other Parts Discussed in Thread: TPS53513, TPS54821, TPS54824
Customer is using TPS54719 in their design.
They are supplying the IC with an input of 4.5Vdc and in some cases, the ICs are getting blown off when the boards are powered ON or when the system is turned ON
Can you please suggest a pin compatible alternate to same IC, with higher input voltage, of the order of 12V or higher?
