BQ24296M: schematic review
Part Number: BQ24296M
Hi Sir
pls help to review BQ24296M schematic. thanks!
By the way, does PMID and VSYS always have voltage no mater VBUS input or not?
SCHEMATIC1 _ 07_Power.pdf
BRs
Eric Lo
  • Eric,
    I will help you to review the circuit then feedback to you soon.
    During AC mode, the PMID voltage will be closed to Vin
    During battery mode, the PMID voltage will be closed to battery voltage
    During OTG mode, the PMID voltage will be closed to 5V
    After reviewing your BQ24296M circuit, I think it should be ok for me. Only one item need your confirmation.
    ==>SCL/SDA pull high voltage is 5V, please double check your system I/O voltage level in case is too high.
