TPS25940-Q1: State of diagnostic outputs when device EN is low
Part Number: TPS25940-Q1
Hi Team,
If the diagnostic outputs (/FLT, PGOOD) are not tied to OUT, but instead tied to a different voltage level to interface with a processor, what is the state of those internal FETs when the device EN is low? Is it possible that there could be leakage current through the pull-up resistor to ground through these FETs?
Thank you for your support.
Jared
