TPS2388: If i want to change the sense resistor as per the 802.3af standard?
Part Number: TPS2388
Hi ,
Thanks for your reply.
as per TPS2388 EVM the sense resistor assign for 802.3at standard. If i want to connect the 802.3af device, I need to change sense resistor as per the 802.3af standard?
or the same design can comfortable with 802.3af standard including over current detection?
