Please advice what IC I could use for my application as Webench tool doesn't show any results. Vin is 3.3V to 4.2V and Vout is 24V 4-20mA. The output must be isolated.
Thanks!
Emilija
Hi Ambreesh,
LM3481 doesn't work using webench. I get a message "Your preferred device does not work with the inputs you selected.". Have you got any more suggestions?
Thank you.
Emilija
Hi Ambreesh,
I tried again and it says design cannot be created with the inputs your selected! I tried selecting LM3481 Boost or flyback version from the drop down menu. And I used the same inputs you tried. I really dont know what I'm doing wrong.
Thank you.
Emilija
Dear Sir,
Please take a look at TLV61046, it can just meet your requirement. And it has load disconnect function.
Hi Gareth,
The input range is from 3.3V to 8V. There is no requirement for switching frequency.
I tried LM5001 but webench didnt work with my requirements.
Emilija
Dear Sir,
Thanks for the update, 8V is a little bit too high for the TLV61046. You can consider to use TPS61170, but this part doesn't has load disconnect function.
Hi Emilija,
It could support 3.3Vin/24V output. you can apply for a TPS61170 EVM board to test it.
