Our customer is using LT3999 as 12V battery to 12V/0.8A solution.
Does TI has any suggestion for LT3999 replacement?
BTW, the much easier the better.
Thank you.
C.T.
Hi C.T.,
Thank you for posting to E2E! The simplest comparable design uses the SN6505 operating at 5V. A transformer with turns ratio of ~2.5 is needed, but this will limit the output current to 410mA.
Is this acceptable for our customer?
Thank you for your time,
Manuel Chavez
Hi Manuel,
The input is 12V battery, and the output need 12V/1A.
Thanks for your information, customer consider about simple solution like LT's.
Thank you very much.
C.T.
