TPS23754: PoE shielding GND
Part Number: TPS23754
Hello Sirs,
Need your experience sharing about PoE shielding GND connection issue .
If the PoE PD tps23754 design for a outdoor product which need to connect shielding case to earth GND.
But the PoE will not workable. Once removing shielding case connect with earth GND then It is workable .
Would you pls kindly give suggestion about this and what's the reason for this kind problem ?
Many thanks !
