UC1843: shutdown using COMP
Part Number: UC1843
Hi team,
I understand that the device can be shutdown by pulling down the COMP voltage to lower than 2 diodes drops. But I wonder what is the specific voltage drop in this situation? because if I use a transistor to pull down the COMP, there might be some voltage cross the transistor and causing the shutdown to fail. Thanks!
George
  • Hey George,
    I have found in the past that the values is approximately around 1.2 V, although this is not a guaranteed value.
    I will say that I have heard of people using the method you are describing and have yet to hear complaints about the shutdown not happening due to the drop across the transistor.
    Daniel
