Other Parts Discussed in Thread: DAC7760, TIPD167, TPS54060
My task is to get +10V and -10V for DAC7760. I came across above similar circuit from one of TI documents.
Can you confirm the part number for L19=744870471. The datasheet for it shows that its a common mode choke only. But it is supposed to be fly buck transformer.(Primary and secondary inverse).
When I implemented above circuit using common mode choke, it's not generating the negative power supply across C199.
Attached herewith is schematic I am trying to implement.DUAL POWER SUPPLY GENERATION.pdf
Let me know if you have any other simple circuitry or suggestions.
Thank you!
