BQ76PL455A-Q1: have inconsistent power consumption issue
Part Number: BQ76PL455A-Q1
Other Parts Discussed in Thread: BQ76PL455A
Dears,
We use 6PCS bq76pl455a-Q1 series connection in one battery PACK,for EV BMS application,it's a all in one BMS design,as below picture:
we test find the last one PCS BQ76PL455A who furthest away from the MCU,have a lower power dissipation compare with others, about 2mA current lower. We add some resistance to dissipation this,but can not make the 6 PCS bq76pl455a a fully power consumption consistent,this issue will impact battery behavior.
So, we want to get some better soluation to solve it,whether TI have optimized on this?
Thanks!
  • Hi user,
    Thanks for the question and I will get back to you shortly, please be patient as many of us are on business travel.
    Taylor
  • Hi User,
    I think your approach is proper way. Your board #1 will have least power consumption due to less communication traffics compares to other 5.
    I think adding a resistor to burn extra 2mA is one of option. You can control the GPIO with a command.
    So, you will turn on the GPIO (add 2mA load) and then do your communication.
    Try this and let us know.
    Roger
